BWOLIVER
1990 2.3 2wd
any words of wisdom on water pump install, never have did a 4 banger. do I have to remove the timing belt etc...?
I also have a leaking freeze plug got the old one out how do I get the new one in? it is the front pass. side by the motor mount
has anyone else had a problem with the neck of th t stat housing leaking due to corrosion?
thank all
this 4cyl is just so different than my 2 84 2.8's
thank all
