3hokies
Well, after searching every concievable spot for the water leaking on my passenger floor board I found the culprit. I ground out all the sealer that I put in last fall when I thought I found the problem and there it was....the entire drip rail had a 1/8" gap between the joints. Not being a welder, I filled the gap with good old JB Weld and after painting it with Rust Bullet and applying seam sealer again hopefully that takes care of that.
