washer toggle
fordfan
Abbotsford,BC
Hoping someone can help... have a 89 B2 and there;s no power to the washer fluid pump. Any tips on where/how to wire in a toggle? I'm not electrical, and can't get it to run when I tap into an open 30amp fuse area under the hood- should I try under the dash? When I connect directly to the battery, the pump runs.
Any help would be appreciated!
PS My wipers also run slower than my ranger used to, but I can't figure out how to get the multi-function arm apart to check the contacts.Could that even be my problem-contacts? I'll take an answer no matter how old this gets!
