CarsonChris68
Can a machine shop fix them if they are out of spec? I took mine off and I don't see any cracks. Mahle heads from Germany. Look fairly clean but might be out a little bit in the middle.
I haven't measured the block yet. You have a good point. I've thoroughly examined the heads and don't see any cracks. I've seen the cracks in other 2.9's that I've had and wound up swapping engines. Passenger side leaked under head gasket. The driver side didn't have leaks.
I recently bought this BII and I'm trying to get her running. Other owner had the bottom radiator hose come off and it over heated. It sat for approximately a year with oil antifreeze mix internally. I bought a pair of "new" heads off the internet that were manufactured in China and I think these are more out of spec than the originals.
What was the company you dealt with online? I want to make sure to stay away from them..I'm sure anyone else with a 2.9 would too!
