open the ash try- remove the two torx screws, i think t-20 or t-25. remove the ash try.
after that there are about 8 clips around the edges of the trim holding it to the rest of the dash. You maybe be able to just pull it apart, or get a flat head behind the trim and pop the clips loose. after that wiggle it out over the steering wheel.
Next you have 4 or 6 more torx screws holding the cluster in. Same size as ash tray.(the black ones, the gold ones just hold the plastic face on the cluster) remove them and pull the cluster out as much as possible. Try getting under the truck and feeding the spedo some slack to the cab to make things easier.
Next remove the 2 electric connectors behind the cluster (one on either side of the cluster). they are rectangular in shape, you need to compress both sides of the clip to remove it. This can be tough, but you'll get them.
After that you should have a little more slack to get your hand on the speedo cable. The cable is attached by a round clip of sorts. you have to pinch it to release the cable from the cluster, then pull it out.
While the cluster is out, you can pull the speed-o cable through the sleeve and out of the truck to grease it.
The bulbs are easy to replace, just a quarter twist and they pull straight out.
This may seem like a lot reading it, but i can have the cluster out of my truck in about 10-15 minutes. Good luck, and if you have questions, just ask.
