Warn hub rebuild
HPI HIGH
Can you rebuid a warn manual hub ? Any info would help like is there a kit available , instructions its on a 92 ranger with 4.0 and dana 35 axil thank you.
Did it break?
Or do you just want to take it apart to clean and re-grease it?
AD
The spring that kicks it out in free position came out but i got it back in . But i did try to take it apart withe no luck i removed retaining clip but could not get the other one that looks like a washer to come out.
IF you make the horrible mistake of taking the knob off and the cam and pressure plate come out of the housing it is a long, annoying trial and error process to get it back together.
I NEVER disassemble one further than what will come out by removing the big inner retaining ring.
AD
