jtanderson
- Sep 22, 2010
- Automatic
no vss speed sensor ( after swap)
ok i own a 1987 ranger ext cab, benn converting this truck to obd2.
all the body wiring, dash, motor, from a 1997 ranger ext cab
the 5r55e trans is out of a 1998 ranger,,
and the engine and trans harness with neutral safety switch and computer are from a 1996 4r55e ranger.
the problem im having is the rpms go way down and almost shut truck off during shift.
ther is no vss speed sensor in the trans, or in the axle housing so i assume thats the culprit.
my question is where would i install a vss speed sensor on my 1987 when theres no hole in the rear axle or the trans for it.
