I hope this is the correct spot to post this question, apologies if not...... I have a 2000 Ford Ranger xlt super 2 door cab sport with 4.0L V6 and Automatic transmission. The other day I noticed the 12v power outlet was not working so I checked my fuses and sure enough blown fuse, replaced fuse and seemed normal, a half hour later I went to leave to go fishing and it was light rain out so I went to turn on my wipers, nothing, I check fuses again, all ok, I use my power probeII and check for ground and power at plug, turn switch to high and check, nothing, apply 12v, wipers move a little try 12v again wipers do full sweep, motor good. start to think mfs (multi function switch) went bad, rain stopped so head out, notice speedometer not working, go back home, pull codes (cel) but dtc P0300, P0301,P0113, P0455, P0203. I also noticed my interior light is not illuminating. I am leaning towards gem, truck has semi rough idle intermittenly but while driving has full power, no chug at all, runs smooth, idle hardly drops 100 to 200 rpm at idle with ac on and rough idle happens for 2 or 3 seconds.
Where should I start? replace gem? short\open wire? Key ignition? Please help.
