KYEdge
Ok I'm starting a new thread about this because I don't think this is related to the oil gauge flicker.
I'm having trouble with voltage fluctuations in my Ranger. I have checked with a DMM and the fluctuations seem to range between less than .5V and right around 1V. At idle, or when the RPMs are hovering around 1K (say when creeping along in traffic), you can literally watch the charge needle move up and down. All of the lights (dome, dash, headlights, and taillights) also get brighter and dimmer as this happens.
The truck seems to run rougher as this is happening, but has not actually stalled or tripped an error code.
There is also a slight surge when you initially give the truck throttle from idle that causes all of the lights to get brighter. Once the RPMs are up the truck runs smoothly and the voltage remains steady.
The alternator has been tested, and appeared to be ok but it was an Autozone test. What am I missing here?
