Decker
- Apr 19, 2011
Found this while trying to figure out if I had Cali emissions or not. Also did the same decoder on my Bronco and both looked correct.
http://www.compnine.com/vid.php
Output:
Report for VIN: 1FTCR10A8RUCXXXXX
1994 RANGER PICKUP 4X2
Built: April 20, 1994
Paint Code: UA
Trim Code: H6
Gross Weight: 4,220lbs
Original options on this vehicle
234,004 vehicles matching your year and description in our database.
Code Description
D3ENP 195/70R X 14SL TYRES
EJABN 2750 LB(1247 KG) REAR AXLE ASSY
EGAGB 3.45
EM0B0 49 STATE/FEDERAL REQUIREMENTS
TR0RQ 5 SPD MAN TRANS MAZDA M5R1
PNUAA BLACK CLEARCOAT
CLMAM BLACK PAINTED REAR BUMPER
EGLAB FORD/VISTEON AXLE VENDOR
CLVAB FRT LICENSE PLATE BRKT/HOLDER
AAGAN LOUISVILLE PLANT BUILT
000YD MEDIUM OPAL GREY
EGJAB NON-LIMITED SLIP REAR AXLE
F07AP NOT DEFINED
F27AY NOT DEFINED
F27HC NOT DEFINED
EN0GR OHC 2.3L SOHC EFI NA I4 GAS*TP
IBAAA RADIO DELETE
AAAAC XL
Output:
Paint Code: UA
Trim Code: H6
Code Description
EGAGB 3.45
F07AP NOT DEFINED
F27AY NOT DEFINED
F27HC NOT DEFINED
IBAAA RADIO DELETE
AAAAC XL
