troymn
- Mar 11, 2016
Hi. I have 2 questions here. (1) I replaced my center bearing with an anchor brand bearing. I made sure to align the shafts to their original spots. I checked and regreased u- joints. Now it vibrates. I put 2 washers on each side of the center bearing thinking that maybe the aftermarket bearing might not sit in the same place and it did help a little. Anyone else have any issues with theses? I have read a lot about the two piece drive shaft issues so that brings me to the second (2) question. I have read of switching to the one piece drive shaft and seen some clearance issues. It's a extended cab 2wd mt trans. Can you run them without hacking and pounding the floor of the cab and hacking out the cross member? Thanks Guys!
