RonSerling
- Mar 25, 2013
- 4.0 V6
- Total Lift
- ummmmm 4" could be 6 but its a TTB and the little bugger varies from time to time !! LOL
- Tire Size
- 33/12.5 15
Hi All !! I have a 93 Ranger 4X4 and it has been extremely gone thru over the past couple years. Brand new 95 4.0 engine and the suspension has a lift with the TTB being completely modified withe 96 Bronco spindles and braking system. I also got a M5ODR1-HD out of a 2001 and put it in there. I got all the parts and did a complete rebuild on the trans before putting it in. Now I have a slight issue I am looking for opinions on please. I have noticed that the truck has a vibration in 4th gear at around 3000 rpm and in 5th at around 2500 rpm. I have checked a lot of things like the front suspension for bearing issues and in test driving it if you get it up to speed and disengage the clutch the engine idles but the vibration is still there. Someone mentioned that improper shimming on the front input shaft can possible cause this as if the shaft is to loose it will cause the inner bearings to not seat properly. Just asking if anyone has had this issue before and if not are there any other areas to look at that I may isolate this vibration to ?? Any replies would be appreciated. Thanks
