Valve Cover Gasket Replacement
Also, is there maybe a video link that I can use? The only ones I can find are without AC.
Its the same to actually remove the VC's between non ac and ac. Just on the AC you gotta remove the AC compressor (4bolts IIRC) and the bracket that holds the AC pump and PS pump. You can keep the PS pump attached you just gotta move the bracket out of the way.
The AC pump you can keep the hoses on just unbolt it from the bracket and move it also out of your way,
