slvr00gt
- Dec 21, 2009
- Automatic
I finally got around this weekend to fix leaking valve cover gaskets and found that the reason for leaking gasket were loose bolts. Head gasket in the truck was replaced before I bought it a few years ago. Mechanic at that time used cork based valve cover gasket. Is it possible that cork gasket shrunk, or mechanic simply forgot to tighten some bolts to spec?
BTW: I used Ford's metal/rubber gaskets this time around...
