bigdan002001
Hey guys, I have been working on my 4.0L and installed the new fuel rail green paper gasket from Ford since I have the 97 model. I was reinstalling the fuel rail and hooking back up the vacuum line on the fuel pressure regulator when I noticed that where it y's off to the passengers side firewall, it all just fell apart! Upon closer inspection it is a smal plastic vacuum line with the larger rubber tips that plug into the splitter at the intake and it plugs into the black ball on the inner fender (A/C vacuum resevoir). So some idiot decided to just stick a big ass rubber hose over the rubber ends to hide the fact that the plastic line inside was broken...so obviously I am getting a major vacuum leak here. Question is, can I just replace this vacuum line with a solid rubber vacuum line the size of the ends? Or do I have to try to go to dealer and get the tiny plastic hose with larger rubber ends?
Thanks,
BigDan
Thanks,
BigDan
