MorganMcCann
When I bought my truck, it already had Rugged Ridge hubs put on. However, when I would accelerate the vents would shift from panel vents to the defrost and back again.
Right now, I found a dry rotted fitting at the three way connector that connects the a/c canister, the vacuum relay and the main vacuum.
Can I just remove the thee way connector and make it into an two way connector and let the 4wd system have no vacuum?
