GKM007
Working my way through a Duraspark Conversion and as long as my wire are correct just have my vacuum lines to connect. In my haste of pulling things out I did not mark them and I am wondering where my hoses go
There is a few outlets on the carb, one on the manifold and the tree in the back. Ones I know of are the one from the transmission, pcv, brake booster. I believe all those go to the tree?
Where do the ones on the carb go? Do I need to connect them somewhere or plug them off? Also the dizzy needs a hookup, unsure where.
Also where can I connect the drivers side valve cover breather? I am going to run a aftermarket air cleaner.
One more newb question, but I need to disconnect the vac on the dizzy when timing correct?
