Vacuum Hose(s)?
Ranger4x4.0
Poplar Bluff, Mo
God is great, beer is good, and rangers are awesome!
1998 4.0.
Scanned my computer today to see if I have any codes (cel doesn't work) and Came up with:
P0174- Fuel System Too Lean Bank 2
P0171- Fuel System Too Lean Bank 1
Says most possible reason is Faulty Vacuum Hose(s).
I had the intake gaskets replaced not too long ago so I wouldn't think it's that.
What would it be? Tia.
Sent from my SAMSUNG S7 using Crapatalk
There are a lot of vacuum lines coming off the motor. Any one of them could be split or loose. Or several of them. Being it's a 98, you probably have the vacuum operated hubs too. I usually start with a visual inspection of all of the lines I can see. I've also heard of people spraying carb cleaner along the vacuum lines with the motor running and listening for a change in the idle caused by the carb cleaner being sucked in.
