niccoIndy
- Sep 25, 2009
- Automatic
I have a 1998 2.5L. I have been having rough idle problems when the engine is cool or cold. In addition if I rev the engine when its cold and let it quickly return to idle it stalls.
The long term fuel trims say the engine is running lean at low throttle openings. + 18% Not enough to set a code, but enough to be abnormal.
So I addressed, the MAF, IAC, TPS, Plugs, Wires, to no avail.
Now I just did a smoke test to try to find a vaccuum leak and noticed a couple things that I am not so sure are normal.
When running the smoke test, I had smoke coming out of the bottom of the saucer/diaphragm portion of the egr, a decent amount of smoke actually. Also it looks like there is smoke coming out of the iac, it looks like there is a little vent built into it which is blowing out smoke.
I just want to make sure that this is normal or not, if not I can see the EGR being the culprit. I am less suspect about the IAC as it appears to have the vent built in for a reason.
Any thoughts??
Any thoughts??
