i want to do a v8 swap on my 89 b2 4x4, but i need to know what transmission and engine, and transfer case set up i need to use. any help will be greatly appreciated thanks!
i want to do a swap because the 2.9 just bit the dust with 300,000 miles on it and im doing a restoration on it! plus i don't believe any ford deserves anything less than a v8. i already hav the 5.0, and straight axles also it will stay automatic.
for that engine you will want an E4OD (thats the auto in the 92 bronco) or an AOD. you can use the stock RBV T-case but I wouldn't. I would look for a 205 or a model 20, you can use the 13-56 from a F-150/Bronco but you will have to clearance the frame
I have an AOD trans in mine transfer case out of a 150 but I had to notch the frame IMO dont even consider the 4.0 its just a glorified 2.9 not to mention my 2.9 bronco would outrun my 4.0 explorer any day of the week
For
