v8 swap ?????
parabellum1130
pa.
i am planing a v8 swap for my 94 ranger 2wd currently has the 4putter ....here are my questions
1... will a v8 out of an explorer fit into it and be a plug n play if i used cpu n eng harn from explorer ...im kinda looking for it to look like it coulda came from the factory with v8
2... will i need heavier front springs or will the ones it came stock be fine??
3... urelated to eng swap how new of body part ( front end, bed, headlights, hoodhttp://www.therangerstation.com/forums/images/smilies/3gears.gif ) will bolt up to my 94 for a newer look :3gears::3gears::3gears:
if your willing to swap the explorer stuff your good to go.....you want the core support/cooling setup too. hvac will need some massaging as well
you will want a fox oil pan though on the tib chassis
