I put an AOD in my 1988 302 ranger 2wd its not that bad if you have the engine out then you can put it in through the engine bay ( thats what i did the last time was waiting on a rear main for the engine) you can also put it in attached to the engine if crank pulley is off the engine still very tight but doable. As for linkage on the AOD watch the monster transmissions video
those are the part numbers I used some other numbers might be in part 2 of the video. I hope this helps on the transmission side of things
For
