- Feb 24, 2011
- Huntsville, AL
- Manual
- Total Lift
- 3 Inches
- Tire Size
- 33X11.5X16 (285/75R16)
I am doing the 5.0 swap into my 2000 ranger 4x4 and am mostly done. I appreciate all the info you have posted it has been a help as I did not buy an explorer/mountaineer to do the swap, I have gathered all the pieces and done the work. In hindsight I should have just bought an explorer/mountaineer. Oh well. Anyway...
Question for you. The last thing I have to do is the battery wiring harness. I don't have the one from the ranger (I sold the motor, tranny, transfer case and all the wiring). So I grabbed one from a 97 mountaineer, it didn't cost me anything. The problem is, it is not exactly what I need and honestly I am not sure exactly what I need. Any info here you can provide is GREATLY appreciated! Did you use the one from the ranger? If not, what did you use? Did you have to do anything to it to get it to work?
Thanks so much for your time,
Clay
The 97 mountaineer battery harness should work. Except there is one plug under the brake master cylinder that doesn't match up and will need to be spliced. The other connections... to the starter and alternator... should be fine.
