It's normal in most cases for a car/truck to use about a qt of oil between oil changes. If you want? Park the truck over a large chunk of cardboard and let it sit overnight. Check for oil spots the next morning to see if there is a leak.
Otherwise if no leak is found, and you're not puffing blue smoke out the tail pipe? I wouldn't worry about it much. My last company van was an 07 Sprinter with the turbo diesel. Started up after each oil change with 13.5 qts of Mobil-1 0w30..About at the 5-6000 mark? I had to add about two qts of the same oil. Dealership also mentioned it's normal, (heck, going 10,000 miles between changes? I'd expect some of the oil to go somewhere into the ozone LOL)
S-
