Urgent!
Fordisthebest30
Firefighter
EMT / Paramedic
Alaska
1989
o have a 1997 Mazda b4000 4x4 and the power doesn't work. I even tried popping the clutch and nothing. I've pulled every fuse and found nothing. I've checked the voltage on the battery and checked the terminals, nothing. Checked the ground off the battery it was good. I'm really stumped. I'm not getting any power at all , idk if there is a relay for the ignition but every time I turn the key there's a click afterwards. I'm stumped and I desperately need help. Thanks
Check the terminal connections on the starter. Same thing happened to me. Cleaned up the starter a bit and was back on the road.
thanks guys. i checked all fuses, and everything was good. i cleaned the grounds, and terminals and it worked. it was just a bad connection on the battery terminals. not a problem anymore
get yourself some of that electrical grease to put on you batt. posts it will help against corrossion
Glad to hear that you found your problem.
