livefastplaydirty
- May 8, 2014
Does anyone know how to, or if its possible to, remove all of the wiring out of a 2001 ranger except for the engine harness itself. So basically just have the main connector on the driver side valve cover and o2 sensors. All this while still using the stock pcm after getting PATS deleted off of it. Boss wants to build a mini stock and wants only bare essential wiring. Also i already swapped out the stock automatic trans to a manual. I wired in the starter to a seperate switch as well as the fuel pump.
