upper fuel line 93-94 - fit 1990?
90xlt
I want to replace the upper braided fuel line that leads to FPR as its leaking at the 90 degree plastic connector. I found a 93-94 fuel line with a newer threaded connection to FPR, should not leak.
Part is off a 4.0L, same engine block I have. Thanks for confirming if this should fit
yes it does!
It was a cracked connector (90 degree elbow) leading off upper rail into FPR. Pulled a 92 upper fuel rail from a 4.0L Explorer at salvage, which had the newer threaded design, Autozone for a new Sorenson FPR and BINGO.
Runs soooooo much better.
