NMB2
July 2010 OTOTM Winner
OTOTM Winner
Solid Axle Swap
after searching high and low in parts stores, I finally found a saginaw pump to direct interchange with the ford pump. I dont know what its application is, only the part number.
the pressure line from the ford pump goes into it... and In this case i used the stock pully from the old pump.. it pressed on all the way and ended up being a tiny bit too far back, but i dont think its an issue.
this was completely a bolt in, direct swap.
