RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
- Mar 15, 2009
- Automatic
Okay, for those not familiar with SVT, I have a 96 ranger 4x4 with the factory 4.0L (long gone), had true Dana 35 twin piston calipers up front with drum out back. For those that don't know, 95+ rangers use the same brake master cylinder as the 95+ 4 wheel disc explorers, so upgrading the rear to disc does not require a MC change...However I am going from a 4 piston braking system (2 each wheel on fron) to an 8 piston braking system (2 each on all four corners), I am basically using the brakes from a 2000 F250 from both axles. I am upgrading to a hydroboost unit and MC from the f250, but here is my question...I will be flowing close to 4 times the factory rate of brake fluid through the factory lines. What do you think/ideas/opinions/criticism on upgrading the 3/16 brakeline to 1/4 or even 5/16 to compensate?? I realize that I will still be able to flow the same amount, but in theory it will take longer for the fluid to reach the calipers, meaning a slower braking response. By increasing the diameter of the lines, it should increase braking response by reducing the friction loss from flow in the lines...
SVT
SVT
