Rockhound
- Feb 6, 2009
I have a 94 ranger, 3.0L, 4x4, manual trans, 140,000 miles. The engine is stock.
I'm sure that I am not the first/only person that would like to hear that sonic boom
as you break the sound barrier on your way to work and drive (fly?) 200 miles to and from work on less than a gallon of gas AND have this a reliable truck. However, the likely hood of that happening is just about the same as me leaving the truck as is and NOT alter and play with something. With that said....
There are a lot of small and large mods out there for this engine. I'm looking a little more power (and something to do) such as power pullies, roller rockers, cams, port matching, head work, injector, etc....
My question is, at what point do you exceed the ability for your ECU and PCM to keep up with the mods without reprogramming anything. I would figure, and stop me if I'm wrong, that there would be some very fine line in which stuff like larger valves, port matching, roller rockers, cam changes, and injector changes would confuse the hell out of the computer.
What is that fine line? How much is too much for the computer? How easy and practical is it to go beyond that line and have the computer reflashed for what you need?
