keithm
- Mar 1, 2011
- 90 Ranger with
ok engine is in and mounted, sent it to the exhaust shop, thay did an excellent job with that.
this is and 84 carb engine, it has a backfire thru the carb, I believe I've got an air leak around the carb base, the air system has been removed and properly plugged, no air pump , no air tube, no egr. replaced the egr plate with a spacer plate, I believe I have an air leak at that point, plus the timing may be retarded
the only thing I didnt replace was the water pump, guess whats leaking, lol
did manage to use the superduty radiator with the v belt set up, there is the issue of removing the water pump, bit of a juggle, have to use pusher fans but its doable.
which brings up a question throttle linkage works good but when I hook up the transmission tv cable, which is brand new and has very suttle bends, it takes two feet to push the pedal down, dam
any ideas?
was pulling it up on the trailer and wow did it want to spin the tires
gonna be fun
any ideas?
gonna be fun
