Update on James Duff lift. 56k no no
ThatGuy
Solid Axle Swap
Oak Ridge, TN
Well it's been a while now(1437 miles actually) since I got the prototype JD 6" lift on my Explorer. Mostly road miles with a few mild off-raoding trips. Just thought I'd update and let you know how it's done so far.
For those that didn't see the original post, it's here. http://http://www.therangerstation.com/forums/showthread.php?t=67520
I started with this
After trading around a few times I ended up with some 35s. They dont fit as good as the 32s with no lift. I had been in talks with the crew at James Duff about doing a SAS kit for a while. They had some things in development and wanted me to try out a new TTB lift for them first. Here is the Ex rolling into their shop (had to trim the fenders to get it outta my garage and to them)
They tore it all apart and installed a new set of coil buckets that will accept either RBV coils or EB coils. The rest of the front end is the same as their Stage 1.5 kit.
Coil buckets
The rear is a new lift spring that uses the factory spring-under configuration to improve stability and reduce spring wrap.
This is it on their ramp. Not too impressive cuz my bumper was dragging going up the ramp and with only 2 wheel peel I didnt have enough to push it on up.
After I drove it home.
That's my stock Jeep Grand Cherokee sitting behind it to give an idea of height.
Ride and drive has been excellent. It has a better ride than when stock. Railroad crossings, speed bumps, and rough gravel roads are all soaked up like they are nothing. I look for reasons to get out of the house just so I can drive the thing (1400 miles in just over a month). The stance is great in traffic, big enough so people get out of your way but not so big that its tippy. If I were going to keep the setup, I'd prolly run 33" tires and be done with it. I plan on going to a SAS when this is done being tested so that's why I have the 35s. I have ZERO vibrations and the suspension doesn't make weird pops and groans.
Unfortunately I dont have any wheeling pix, I've either been by myself or not had a camera along. The only snaps I have are a couple poser shots I took while me and Jim were at Windrock yesterday.
And then it went BOOM! Or better yet,,POP, POP, POP, POP,nothing. About 25 feet from where the pix were taken I had my lovely auto hubs grenade on me. Had to turn around and head out in 2low.
To sum it all up, on pavement or in the dirt, this kit rocks! I have zero negative to say about it so far. I am very impressed with the flex, stability, and overall ride.
Biggest thing now is should I spend some money to get manual hubs so I can wheel a little more before doing the SAS? Just go pick up some junkyard autos for spares? Or just keep driving it on road only until the SAS?
So why do a SAS then?? :icon_confused:
Get the Jeep hubs for it and be done with it.
(Or is James Duff taking their kit back?)
I've had the d44 and 9" since way before I done this lift. I talked to them about helping come up with a bolt in SAS swap kit. They agreed but needed a vehicle to test their new buckets on. Since the point of the buckets is to be able to convert to a SAS using EB coils after running a regular TTB lift, it might as well get tested on both lifts. I agreed to do the testing (didn't have to twist my arm) on both kits. So I will be running the TTB lift until we do the SAS.
I would have rather went straight to solid axle but, hey I gotta do my part to help the RBV community.
