Turnerbryan
2003 for ranger XLT 3.0 automatic.
Hello, Swapped a trans that was hard shifting from all gears. The new/used trans started doing exact same thing until I changed the VSS and idle air intake control valve. Now the trans is not shifting from 1st to 2nd until I let off gas pedal, it will run rpm up to 3-4k and I let off gas and it will shift into 2nd, and run through others gears. Also no hard shifting anymore.Any help would be appreciated. Thanks
