Unknown Wire
6herald6
3.0 V6
I was pulling plugs when this gray wire (see attach.) got disconnected but I don't know from where? It runs under the heater core housing and blower motor and maybe enters the cab. The blower motor still runs so it's something else.
Thanks for the help.
Fred
Its not a wire, its the hose that connects to the heat / bypass control valve, in your picture the valve is just to the right of your hand and has heater hoses going to it, the hose connects to the back / bottom of the valve, if you look close you should be able to see the port where this hose connects
JP02XLT
Hi JPO2XLT,
From your description this hose connects to the back/bottom of the round, gray disc with the little "spokes"?
Thanks for your help, JPO2XLT.
Fred
Yes Sir, sounds like you have found it from my less than stellar description, Should easily plug onto the back / bottom of that valve, it is the only port on it & I think mine has an elbow on it.
JP02XLT
