Just a few questions:
1) Are they worth the money?
2) Do I have to get an under drive pulley to replace each pulley under the hood or can I get away with just replacing the crank pulley or will this not have the same effect?
3) Since the under drive pulley slows down the accessory pulleys, does this mean your alternator does not put out the same amperage as it would with stock pulleys?
4) Has anyone used them and had a noticable difference in Hp?
5) And if anyone has used them can you recommend a good/affordable brand?
Any help is much appreciated.
Thanks
Thanks
