bob123
- Jan 22, 2008
- Age
- 58
I replaced my hanger bearing a month or so ago....I had to drive about 40 miles home with no hanger bearing. Since it has been placed driveshaft make an awful grinding squeeking noice....Is it possible I bent the drive shaft. I did mark it before I took it out so i made sure it went back in correctly. Or is it something as simple as changing the U-Joint....Yeah I know I should changed them the same as the hanger bearing but did not ....I was not sure how to change the u-joints (still don't know) If some could help that would be great. I think if I can change the hanger bearing the U-joints should not be that much harder.
