Two piece drive shaft
max
Any way to fix the two piece drive shaft so it slides easily? I have been putting white grease in it about every two months works for a while then back to the same thing and it is a pain to try and do in the winter. Thanks
Never mind
I asked the wrong question I was speaking of slip joint on the drive shaft and I found the info.
Yeah, use the correct grease. Light blue, teflon based.
Ford has the Tsb on it just use the ford ptfe grease it's blue comes in a little squeeze tube. Like $8 at the dealer
