Well it wont work in that spot but found another and it will do better there, aka, bolt it up to the other alternator bracket. My only thing is being able to tighten the belt (should have taken a picture of it all). And since the alternators pulleys are almost in line with eachother, I may run a larger pulley on one so that it will have more surface for the belt to touch (no to big) but enough both can turn. Its going to take some playing around but will get this figured out along with pics so that I can still get advice from all of you.
Now another question. Found pulleys at my local farm store that are cast metal and was wondering if they would be good for running on my alternator? They have the correct center diameter but have a screw that tightens them down though that may no be need since the alternator has one (but keep it there to balance it out). If so I may run the 87 one due to it has a 61 amp output on it for now vs the 40 amp one it has now. And since it has the built in regulator on it, Ill just hook it right before the soleniod (just like the setup I have now) and I, in therory, should be good.
One way or another, I will have 2 under the hood of this truck, Im wanting to put more electrical things on this truck, such as a winch, and will need to do what I can, as cheap as I can.
