Two 6 Volts.
Haywire6000
RBV's on Boost
Winthrop Maine
2.3 (4 Cylinder)
Total Drop
2" Shackle Drop
Just wondering if anyone had ran two 6 volts in series instead of one 12v.
Most 6 volts seem to be smaller and have the same amperage as a standard 12 volt. So two 6 volts with 800 CCA wired in series would get you 12v 1600 CCA. So it makes sense, I am just wondering if anyone has done it.
You would have 12v, 800 cca. When you series, you double the voltage, not the amperage. When you parallel, you double the amperage, and voltage stays the same.
Series = 12v, 800 cca
Parallel = 6v, 1600 cca
SVT
hmmm. Crap, your right. haha
