stx4.0
- Feb 24, 2008
I bought 2 rangers last year from different people that got them hot.I got good deals on both but am having trouble fixing the overheating problem.One is a 4wd that the water pump went out and went out bad from what I was told.I guess it lost all coolant within minutes out the weep hole.Anyway I pulled the heads and one of them was cracked,neither one was warped though which was strange as it got hot enough to pop the overflow hose off and spray coolant everwhere under the hood.I bought new alabama cylinder heads and put a straight edge on the block and the block checked out so it all went back togeather.I also had the radiator cleaned just for insurance as it looked really clean anyway and bought a new thermostat.After I put it all back togeather and fired it up it still wants to get hot and acts like theres no coolant at all in it.Once the temp gauge starts to climb it keeps going.I pulled the thermostat out and ran it that way and it had no effect which really puzzles me.My only thought now is I had to miss something when I put the straight edge on the block even though I was very thorough when I done it.Does anyone else think the block is probably warped or is there some trick to the 4.0 I dont know about?I am holding off working on my other 4.0 untill I know for sure how to fix the problem.I also pulled the thermostat out of it to see if it had any effect and it did the same thing the other one did.Anyone got any ideas or thoughts on anything I might have missed?
