- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
Mounting it isn't quite the problem, not directly anyway. Finding a good married 205 is the one of the issues given how old they are now. The other is that, if I can find one of those, I'll also need to change the transmission to use it. The 68-72 F-100 4x4 used a Dana 21 single speed transfer case mounted to a 2wd NP435. The 205 and the transfer case adapter will not bolt to my existing transmission. So I'm really looking for a 435/205 combo.FWIW my 205 is on a 2004 5 speed transmission, it is the standard fullsize Ford 6 bolt pattern.
Frankly I don't need the 205, a later transfer case would work just fine and be plenty strong enough for my purposes. If I'm going to swap to a later more available transmission, I might as well buy the matching transfer case right along with it. IIRC a ZF 5/6 & transfer case from behind a 5.4 or 6.8 V10 would be a good option and adapters are available to put a mod motor transmission behind the FE. Hell, I'd go for the ZF-6 and NP271 that's behind the 7.3 in my F-250 (buying another set of course), but the gearing is way off for a gasoline engine from what I understand.
Just so happens that the Mod motor transmissions would also work behind the Godzilla. If did the transmission/transfer case swap first then decided to go Godzilla instead of FE rebuild I'd be covered with the exception of possibly having to get driveshafts remade again.
This ain't about my projects though. I was just sympothizing with Lil_blue's parts hunting delemas. We seem to be sharing a few parts availability issues among our projects.
