Twin I beam drop bracket questions
One of my drop brackets for the I beam is cracked on the lift kit that I got. It's a skyjacker 6 inch long arm kit. I'm looking online and the drop brackets say they fit a 4 to a 6 inch lift? Can anybody confirm this? I don't see how they could fit both without throwing off the camber. Second, if I can't get a bracket from skyjacker would any brand of bracket work? Say from superlift or james duff? Thanks.
The Skyjacker brackets have two sets of holes for mounting the axle depending whether you use 4" or 6" lift springs.
And yes, you also could substitute a bracket of another brand as long as it's made for the same amount of lift.
