Turbo swap. What all is needed?
Ok I spun a bearing in my 2.5L and I'm thinking that there's no better time to turbo my motor than while I have it pulled for a rebuild. While I have some idea of what I'll need for the turbo swap, I'm still pretty clueless for the most part being that I've never seen a turbo Lima in person to study what all is changed out/modified. I'll list what I know I'll need to get and you guys can just tell me what I'll need just to get it running.
Turbo
Turbo manifold
36-42 lb injectors (or what do you suggest?)
255 fuel pump
Felpro gasket (I forgot the exact one was needed...)
Bigger Throttle body? (not sure here that's why I'm coming to you guy's)
Bigger MAF? (once again not sure if it's need so inform me if I'm wrong)
BOV (not sure which one to get)
TC flywheel and PP
And that's all I can think of.
what are you using for internals
you should have put this in the forced induction section. go to turboranger forums and click on the lima builds. there should be a sticky of what is required
just buy my whole truck, everything is there.
