Tune up the 99 3.0 tomorrow...
RumpRanger98
Tacoma, WA
Im thinking...
PCV valve
oil, filter
air filter
plugs, wires
not sure how the cap/rotor or whatever it is, havent dug into it yet
what else you guys think?
is there a cap/ rotor? it looks like theres a cap,where all the plug wires run into, but when i look it up on schucks, noone of them look like they are the right ones.
I just bought some MAF meter cleaner from Murrays Auto made by CRC. You disconnect the air hose from the air filter box and spray down the internal sensor with this special cleaner. Evidently it gets dirty over time and a good cleaning helps it to do its job better. Special MAF cleaner - no carb cleaner - and no touching the sensor, just spray the shit out if it and let it air dry. Also since the air hose is off take a look at the throttle body interior and see if it's all carboned up, should not be black. They make a special cleaner for that also. It has to say "For Throttle Body Cleaning" on it because the interior has a special coating you don't want to take off.
change out the rear differential fluid as well. Real easy job. get the cover off, drain, apply some sealer, tighten it on. let it sit for a little while, refill it with fluid. done :)
