Truck wont start.
eduardo95
Bluffton, South Carolina
I have a 95 2.3 4banger with 130xxx miles on it and haven't had a problem for over a year since i had it. BUt today, i decided to move the relay for my roll bar lights from the engine bay to the interior, behind the dash. I did everything and al went smooth but when i decide to get the truck out the garage it wouldn't start. The battery has power and all but it just wont start. I thought it could be the battery terminal that was loose or had some rust so i cleaned it and tightened it, but still nothing. After realizing that wasn't the problem i went with auto scanner because my check engine light is on, it throws no error codes whatsoever. I have no idea what is wrong, im just hoping its not the fuel pump or starter. Any ideas????
well without the engine running, the engine light will stay on.
Check for any lose grounds first.
lets start with basics, does it crank?
if no, do you hear a click from the starter relay when you turn the key? (may need the hood open to hear it) if you dont, check the relay. if you do check the starter for proper wires connected.
if everything looks ok, check the fuse box. i like to use a led keychain light behind the fuses to quickly see if any have blown.
now, if nothing still, make sure the truck isnt out of gear (idk if your auto or not) also, check any wires the relay was hooked into. anything from the battery back. if you trace down the steps you took moving stuff, you will find the problem. you may have left a wire off, or not put back a fuse.
let me know.
While i was at work i remembered i had disconnected a black box from underneath the steering wheel. Since i had no idea what it was and considering the previous owner had some old satellite radio hooked and left everything there i thought it wouldn't matter. So when i came back i decided to hook it back again and the truck decided to start. I still don't know what that box is but i will definitely look into it.
