Tying up loose ends on my 2.3 to 4.0 swap and i converted the 4.0 from an auto to a 5 sp in the process and at a standstill on my ignition. It cranks over and starts fine from the solenoid on the fender but it wont do anything when I turn the key over. All the gauges and accessories work so I know the ignition is good. I've messed with the clutch safety switch, and even bypassed it but still nothing. I'm about to wire up a push button start if nothing else in a day or two but I was just wondering if anyone else has had the same problem or knew anything else to check. Thanks!
