Truck side trailer wiring problem
tx_pwp5
Austin, TX
2.9 V6
4 inches
31x10.50
More auto shenanagans on instagram @waterloocustomworks
I've got to pull a trailer about 250 miles tomorrow morning. The last time I used the light kit they worked fine (magnetic harbor freight set)
After their last use, I put them up like normal and they haven't been disturbed in about 6 months. They were new before that.
I hooked them up to the ranger, the truck side (TS) plug was pretty stiff and I wasn't getting a good connection.
I replaced the TS plug with a quick-fix crimp version from autozone.
Now, the lights are as bright as they should be, the flashers work, but trying to use the right or left side blinker makes both flash at the same time and fairly dim, and when I press the brake lights the trailer lights go off, then come back on when I let go of the brakes. They look fine when the lights are on in a running position.
I made sure all the wires are going to the same terminals as the original plug.
Any ideas?
Likely a bad ground or shorted wires in the connections.
Also, double-check the pin-out to make sure they're connected correctly, which may not be the same as "the same way they came off".
Just learned for the 129871298123 time that the "quick" solution never ends up being quick.
I hard wired in another plug and it works fine. Thanks guys!
