sts95ranger
- Sep 15, 2008
- Automatic
I have been chasing a coolant leak for a while. About a year and a half ago my truck with just 100k on it started to run hot.. I took it to a local mechanic and he changed the water pump and the thermostat. It seemed to help, but the truck still smelled like coolant. The temp gauge also now sat on the lowest line on the gauge even when the truck was at full temp. I found out that the thermostat housing was bowed and would not seal. I changed that and it seemed to help a tiny bit, but it still seemed to run a little warm. Well a couple months ago the truck started to run warm again and I have to run the heater to keep it under control.. So I replaced the water pump again. The gasket on the water pump looked like he had just put it on over the rust and not even cleaned it. Then I had a leak with the lower radiator hose to water pump piece and had to replace that and the seal. Now the truck does not seem to be leaking any coolant. However the truck takes a while to warm up and when you drive it the temp still climbs up to about 1/4 of the gauge. When I turn the heater on it falls back to the lower line.. The top hose of the radiator gets hot. The radiator gets hot, but slowly, and the bottom hose seems to take a long time to get hot and never gets anywhere near as hot as the top hose.. I know it goes through the radiator, but its a pretty big difference.. So I have replaced the thermostat since it started doing this and it didn't help..
Any suggestions? replace the radiator? The coolant does seem to have some sort of metallic color to the very top of it when you uncap the radiator.. Someone told me that sometimes means there isn't much flow in the radiator..
