Troy Lee Suspension
twonole
Apollo Beach, FL
I'm looking to do a lift kit within the next couple of months to a year(depending if a do a body lift first), I'm having a hell of a time figuring out what king of suspension my b3000 Troy Lee has. Could someone help me with this, I've looked under the front(torsion bar or coil spring), but i'm not very knowledgable about suspensions here. And another question is, if I do a body lift, are there brackets available so my rear bumper can remain attached to the frame for towing?
your gunna have torsion bars, if you look under your truck right about where the front of the cab is you will see a cross-member with 2 bars running from that to the lower control arms. crank the tbars enough to level the truck and go with a spindle lift, with some 33s would look clean
