mightymaz
- Mar 20, 2011
- Automatic
Ok, I have a 1998 mazda b2500 single cab and I have been having a few problems. I put a new motor in it, new exhaust, computer, wiring harness, starter, neutral safety switch and some other stuff in it and i had it running perfectly
I am having two problems now,
one is that the key will not start the truck, i must reach underneath and jump it off at the starter. when i turn the key to start the truck i hear a long beep, then a click, and whenever the key is turned to start the truck the parking brake light turns on. WHY?
the other problem is that I keep on blowing the 30amp PCM fuse in the fuse box on the rear driver side of the engine compartment, why is this? and how do I fix it? thanks!!
